Holley 390 to Offy 360
sean
Post by sean »
Well not being able to afford the Edelbrock 500 bits and bobs I have elected to go the above route. Hmm!! Now I need to find the adapter plate that mates the two together, having got the carb and inlet manifold sorted. Any suggestions, anyone as to where I might get one?
Also does nayone have any thoughts on their experience of this setup on their 3.5 or recommendations?
Thanks for any help.
Paul B
Re: Holley 390 to Offy 360
Post by Paul B »
sean wrote:Well not being able to afford the Edelbrock 500 bits and bobs I have elected to go the above route. Hmm!! Now I need to find the adapter plate that mates the two together, having got the carb and inlet manifold sorted. Any suggestions, anyone as to where I might get one?
You can buy ready made adaptors from Summit, to match the carb to the manifold. I made one myself from 1/2" as I'm a masochist like that . :D
sean
Post by sean »
Thanks for that. Never heard of them but I guess a google search should do the trick.
minorv8
Post by minorv8 »
I thought that the manifold has the same bolt pattern than the carb ? Holley and Edelbrock carbs share the same pattern.
JP.
Post by JP. »
sean
Post by sean »
Thanks.
No not the same bolt pattern at all. The manifold bolt holes are much closer together than the holley#s mounting hole.
Pocket rocket
Post by Pocket rocket »
Any chance you can post up a pic , Sean.
Just checked & my Offy (JWR) has 8 holes - thought this was standard
Image[/img]
sean
Post by sean »
Mine has two oval slots and not like yours. The ebay link for it is.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... otohosting[/url]
sean
Post by sean »
It seems it's the wedge plate I need which is proving a little tricky to get hold of. I would have thought this quite standard set up. It appears not.
JSF55
Post by JSF55 »
When i clicked on ur link at the top of the page was a list of simillar items on ebay, in it was a 5 degree plate from paul at V8tuner !
ebay 280154105961
So thats where it went !
Pocket rocket
And strangely it's a couple of quid cheaper direct from his website
http://www.v8tuner.co.uk/product.php?id=114
Paul B
Post by Paul B »
minorv8 wrote:I thought that the manifold has the same bolt pattern than the carb ? Holley and Edelbrock carbs share the same pattern.
No, as I discovered after buying a new £220 Weber 500, then having to lash out another £190 for a manifold as it didn't fit my Offy 360 :cry:
CJV8
Post by CJV8 »
This is a bit odd as I took a Holley 390 off my Offy 360° and dropped an Edelbrock 500 straight onto the same studs.
Marcos Mantula Coupe, in many many pieces.
And places, like the shed, the garage, the house, the garden....
One day.
sean
Post by sean »
Yeah, I saw the one from V8 Tuner but looking at it I just don't think the holes are far enough apart for the Holley and the Offy. Besides I had actually mailed Paul at V8 tuner and he said it would need to come from Offenhauser, for which I haven't yet found a proper site.
I have a feeling that I may be in a similar position to Paul B.
For what it is worth the mounting holes for the Holley are approx 194mm diagonally and 137nn for the Offy carb mounting holes. The pic of the V8 tuner one certainly doesn't look that far apart.
Agreed! Weird! One would have though it was simple.
I wont even mention trying to get a rebuid kit for the exact carb number. How much can a 390 cfm 4160 Holley really differ?
JP.
Post by JP. »
sean wrote:.... it would need to come from Offenhauser, for which I haven't yet found a proper site.
http://www.offyparts.com/ its that simple..
Next option, you only need the adapterplate to fit the holley pattern carb on a Offy patern intake. You could take a normal 1" Holley Alloy carb spacer, drill the extra holes for the Offy patern and here's your home made Offy carb adapter. Ohh forgot, you'll need Allan bolds to fit the adapter cause the'll sit in the adapter.
