3.9 hotwire efi wiring questions
Seight-V8
Post by Seight-V8 »
hiya all,
Been converting my westfield seight from flapper to hotwire efi.
Engine now running, but i have 2 unanswered questions.
1. the efi warning light wire (black/yellow) from the ecu, then to the light, then does this go to earth?.
As the range rover haynes manual shows this goes to a (white) positive lead from the light.
so which is it earth, or positive, dont want to frazzle my new set up.
2. the manual sense resistor wire (orange/black) from the ecu to a 510ohm resistor, do i just wire the other side straight to earth.
many thanks for any help.
scott
vdub boy 1
Post by vdub boy 1 »
Scott,
Not to sure on the ecu warning light - yet to wire mine up , but as far as the mannual sense resistor goes I wired it straight to earth - everything seems to work ok on mine.
cheers
Leigh
Seight-V8
Post by Seight-V8 »
hiya,
Are you sure this wire goes to earth and not to the a positive wire.
as here is a check from the range rover v8 manual
129. On models fitted with a manual gearbox, check the gear switch signal as follows. With the ecu multi plug connected and ignition on connect a voltmeter between pin 34 and earth.
A reading of between 1.4 and 3.5 volts should be obtained, and this takes into consideration the gearbox resistor of 510ohms.
And the wiring diagram from the range rover show a live feed from a white/red wire from the ignition swtich.
any ideas, how much difference this make if its not wired up.
thanks again
scott
vdub boy 1
Hmmm, will double check, and post back
Leigh
alex
Post by alex »
Hi There
Standard Rover wiring colours White with red trace is +12v to starter solenoid.
This tells the ecu its cranking.
Would think you need it.
White wire is always +12v ignition feed. the ecu pulls up to 12v on the warning lamp and it goes out as 12v -12v =0v.
No experience of the tune resistor though.
Hope this helps.
Alex
v84x4
Post by v84x4 »
hi i did this to my racer a few weeks ago earth the 510 ohm resistor to a very good earth mine fired up on the first key turn
