Engine Building...
need4speed
Engine Building...
Post by need4speed »
When it comes to the trusty rover, what is the most comprehensive book regarding engine rebuilding?
v8alex
Post by v8alex »
I would use the Rover V8 overhaul manual. You can find it often on CDROM on eBay. I've got a pdf copy somewhere if you want.
Get a Haynes manual too, and you should have all you need.
Alex
need4speed
v8alex wrote:I would use the Rover V8 overhaul manual. You can find it often on CDROM on eBay. I've got a pdf copy somewhere if you want.
Alex
Thanks alex. you have a pm
Post by ian.stewart »
Depends if you are building a stock or performance engine, Stock will be covered by any amount of "works" type manuals,
David Hardcastles Tuning the Rover V8 is a bit of a Bible.
THE SMOKING GNU
v8alex
Post by v8alex »
I forgot about the David Hardcastle book - I have a copy too and it is really good with lots of pics. It'll complement the other literature nicely.
Alex
