Hi Marki, thanks very much for taking the time to post that...much appreciated. The system has seemingly been working okay for the last year and a half but has been playing up for the last couple of trips. The 2 mini rads have the electric fans on permanently. The right hand rad gets much hotter than the left rad..? Ive noticed a very small drip/leak from one rad when parked and assume that the system is loosing pressure and therefor boiling up.. Instead of getting 2 standard rads to replace, I took the opportunity to get a pair of high performance 4 row... When I removed the old rads I discovered a strange set-up..
The top frame tube is the resevoir/ filler...
It doesnt have a standard inlet manifold. There are 2 'outlet' pipes at the front of the engine, left and right that run seperately to the top of each rad..???? Then the 2 returns from the bottom of each rad connect together and run up to the waterpump.
Also there are very small 'overflow' connectors on each rad that connect together then run up to the filler neck...
I am thinking of doing exactly what you decribed/suggested, in as far as running the water through both rads in turn... (in series and not parallel)
Are the small rad overflow pipes needed..? Why was one rad cooler..? I have blown into and ran a hose through all the pipes and found no blockages or restrictions anywhere...
I am also modifying the rad mounting brackets to bring them out, more square to the airflow..
Heres a pic of where the hoses to the rads come out...
Heres a pic of the filler neck, showing the return pipe attached from the overflow on both rads..
And heres a pic showing right in the middle the 'T' piece where the 2 rad overflows meet before going up to the filler neck...
Your thoughts would be most welcome..
Bazza
