A pair of classic P6 Rovers
- Helpful or Confused
I own two early '70s V8 Rover P6 saloons, both white with black leather interiors, both languishing in a dry garage here in Berlin awaiting extensive welding to make them roadworthy again. One is unmolested, the other is lowered on a full set of poly bushes and gas shocks with a mildy uprated balanced 3.5 litre SD1 short block. Through a standard exhaust the Kent 214 cam produces approx. 160bhp. It made more power with an Edelbrock Performer intake, Holley 390 and MGB 4into1 block huggers than with the original SUs but was thirstier too!
I hope to get started welding them back up in the new year... just got to learn to weld now!
'72 Rover 3500, 6yr back-to-the-bare-Base-Unit nut & bolt resto finished in time for her 40th birthday June 2012!
- Getting There
...years later, and I'm still not finished! I decided to strip the 'unmolested' car when it turned out to have been bodged and blown over for a quick cash sale.
Figured I could cannibalize the best bits of both cars to make one really good one. Got stuck right in and tore it all apart, back to the last nut and bolt. A man needs a hobby, right!? Cor blimey, but it doesn't half take a long time to get everything refinished and get it back together. I've had the chassis stiffened, the suspension lowered and poly-bushed, the brakes rebuilt with stainless pistons, swapped in the PAS, got the better of the two engines installed, added the repainted intake manifold, carbs and valve covers today. Need to find enough cash to afford a decent new paintjob next...
- Getting There
It has been quite a while since I've been on the forum, and even longer since I started taking my '72 P6 apart with a view to restoring her! I'm delighted to report that my project is now more-or-less finished, apart from a few little niggles! I very much hope to get it through the very strict TÜV (MOT) full inspection next week, and back on the roads at long last. Fingers crossed!
Here are a few snapshots for your delectation:
Passed the first TÜV this week with no advisories. Two years of V8 motoring since I got the car back on the roads, lots of little niggles corrected, no major problems, now has Kenlowe push fan in front of new rad, next project is to install an LT77 5-speed gearbox.
The US export P6 was fitted with a different air filter box to the UK and European market cars. It features a cold air intake that meets the long scoop on the middle of the bonnet. It also has a warm air feed from a collector around the driver's side exhaust manifold. The cold/warm air mixture is controlled by a bi-metallic strip and a vacuum unit.
