We tried it round the industrial estate first (not on the road, honest guv'nor).I think it's pretty brave to take a new car on the track without some testing first!
http://www.evanscooling.com/main25.htmEVANS NPG+ Coolant is a blend of glycols with particular additives that do not require water to remain in solution. As it remains substantially vapor free in the coolant jacket, liquid-to-metal contact is maintained regardless of coolant temperature or engine load. By bathing the entire coolant jacket with vapor-less coolant 100% of the time, metal temperatures are controlled to such an extent that critical levels of detonation and pre-ignition are never reached. Because EVANS NPG+ boils at 375 degrees F, the need for high pressure in the cooling system is eliminated. The only pressure generated in an NPG+ cooling system is due to the expansion of liquid, never by the formation of vapor. Consequently the build-up of pressure in a system using NPG+ is typically in the range of just 2 to 7 psig and gasket seals, hose connections, and even the radiator core, are under less stress and operate safer and longer.
