My issue is sporadic in that it runs lumpy and very rich (black sooty smoke from exhaust, black plugs etc). However, sometimes, occasionally it runs sweet as a nut, which leads me to suspect something is sticking or loose. Today when it changed from rich to OK, she conked out and was hard to start again.
Initial impressions would lead me to the fuel system, but originally when this was happening I noticed that the purple and orange wires from the dizzy had a bad connection which seemed to sort it for a while.
So, my preference is to look on the ignition side, but in order to help me start more detailed diagnostics, could this be ignition or more likely fuel related?
I have diagnosed so far that there is a leak in the vacuum on the dizzy, but am assuming this shouldn't effect it this much. I also have what I assume is an ignition amp connected to a relay (not mentioned on the ignition upgrade thread) and it does have the in line resistor(?) on the coil.
Help appreciated as Summer is coming
