Manual required
Manual required
Can any of the learned members point me in the direction of a Repair and Overhaul Manual for the ZF 4HP22/24 gearboxes, please?
- Rossco
- Moderator Gold
Re: Manual required
Chris is a member here and should be able to assist
http://www.cowdery.org.uk/zf.php This is his website
Re: Manual required
Re: Manual required
Depending on what you are wanting to do, a copy of RAVE (the Land Rover CD) for a Range Rover Classic is the most complete documentation I have found. Although the same box was used on the Discovery 2, Range Rover P38, their documentation is much less complete. Clearly you just changed the transmission on those vehicles rather than repaired it.
I can arrange for a copy of the relevant RAVE chapter if you PM me.
Re: Manual required
Hi Chris,ChrisJC wrote: ↑Wed Nov 04, 2020 9:57 pm Depending on what you are wanting to do, a copy of RAVE (the Land Rover CD) for a Range Rover Classic is the most complete documentation I have found. Although the same box was used on the Discovery 2, Range Rover P38, their documentation is much less complete. Clearly you just changed the transmission on those vehicles rather than repaired it.
Thank you very much, PM on it's merry way.
