PEM101130 connection sizes.
jenko
Post by jenko »
On the off chance, does anyone know the port sizes on the pem101130 Thermostat . I realise the main rad in and out are 32mm, it's the other two (thermostat bypass and header tank / heater) connection sizes im looking for. I suspect they are either 16mm or 19mm, or indeed a mix of both....but, could be wrong on that?.
Building a westfield V8
Re: PEM101130 connection sizes.
I think they are 19, but I will measure one later.
jenko
Post by jenko »
Thanks Chris.....That was my thinking...the outlet on the manifold is 19mm.
The middle one is 19mm and the one at an angle is 21mm.
jenko
Post by jenko »
Thanks Chris......I can get on with ordering the hoses...cheeers...Paul
Return to “Cooling Area”
