New rear seal needed on T5 box
Can anyone tell me a good place to get T5wc spares please? I need a new rear seal on the box, it dripping very slightly.
I need the Sierra one not Mustang.
Thanks Mark.
Thanks Mark.
Mark
- Seight-V8
- Knows His Stuff
Re: New rear seal needed on T5 box
try here....should be the ones you need.
https://www.bearingkits.co.uk/FORD-SIER ... LS/224.htm
had mine rebuilt here.
https://www.gearboxman.co.uk/
they might be able to help also if your stuck.
regards
scott
regards
scott
If it's just a regular seal, get the measurements and buy a seal
Some seals are bi-directional, some directional, so take a note of that as a trans output shaft tends to be anti-clockwise rotation.
Thanks Guys.
Managed to get under the car and get the numbers off the seal.
They are TC 35 55 9 and TT0 E509. Shaft is 39.9mm diameter.
Thanks for the information where to get the seal.
Mark.
Mark.
Mark
often the numbers will be measurements. 35mm ID, 55mm OD and 9mm deep.
That would make the 39.9mm shaft size seem very odd for that seal.
eg
https://www.fpeseals.co.uk/seals_1/rota ... 46?page=13
https://www.fpeseals.co.uk/seals_1/rota ... 5&depth1=9
https://www.bearingrevolution.co.uk/35- ... nb7c-44780
I have ordered a new seal.
The size of the output shaft is 34.9mm. Not 39.9mm as I previously stated
What method do you guys use to get the old seal out? I simply use a srew driver, deform the seal and lever it out.
Is there another way?
Thanks Mark.
Thanks Mark.
Mark
That makes more sense.
This is a fairly typical tool for removal...and as long as there is room they do work superbly.
https://www.ffx.co.uk/tools/product/Sil ... nIQAvD_BwE
but a screwdriver is an option too, or some might try and screw a screw into the seal and pull out out with that
Didnt think of the screw idea. Seems simple enough and may be safer, dont want to damage the case.
Thanks for the idea.
Mark
As long as you're careful with that tool, they really are superb. I've never actually tried the screw method myself.
Thought I would post this so someone can learn from my mistake.
I assumed the prop seal was leaking, so I ordered a couple of seals.
Jacked car up, made safe on stands. Removed under tray to expose prop, no leak!! Further investigation found the drip was from the bush I made when I took the speedo drive out.
So a bigger "O" ring later and some sealant, all seems ok.
Assumption is the mother of all cock ups.
M
M
Mark
