Half resin filled
Half resin filled
A while back I bought a 302 block that I was going to put into the GT40
It was recently sent to an engine shop which advised the block was half filled with resin
Does anyone have any idea what this is done for as no doubt it will seriously effect the cooling of the block.
The engine builder says it is not usable in a road car.
katanaman
Post by katanaman »
short running drag race engine maybe http://www.enginebuildermag.com/2014/07 ... k-fillers/
Cheers Marki
So a boat anchor it is!
Or a dodgy wine rack
katanaman
Post by katanaman »
Paint it silver add a bit glass and you have a coffee table. If your married then yes it's a boat anchor.
Sling it on FleaBay as an ex-drag bock awaiting it's resurrection and subsequent glory at the Pod.
Someone's bound to bite and get your money back for you.
Rossco
Moderator Gold
Moderator Gold
Post by Rossco »
If its been done correctly it'll have no effect on cooling.
90% of the heat generated is in the top 20% of the cylinder.
Do run an oil cooler though
Rossco wrote:If its been done correctly it'll have no effect on cooling.
Rossco, does that apply to a road going engine?
Cooling in a GT40 can be marginal at best of time.
Mainly to do with th 7 foot pipes to and from the radiator with the additional drag etc on moving the coolant and when slow you get no air movement around the block (good when it is batting down a track though)
So if anyone fancies a 302 block half filled there will be one hitting e bay soon
I think I may just stick with the bend over unit I have!
They do it to try and strengthen the block. But often as you say it's drag cars where cooling systems only need to run for short periods, or cars running on methanol etc, which by nature also run much cooler, so a loss of water in the cooling system is no big deal.
For a UK driven road car running at normal operating temperatures, I wouldnt be wanting a block like that. But it really does depend how much has been filled.
stevieturbo wrote:They do it to try and strengthen the block. But often as you say it's drag cars where cooling systems only need to run for short periods, or cars running on methanol etc, which by nature also run much cooler, so a loss of water in the cooling system is no big deal.
Are there any chemicals which could dissolve the resin without doing damage to the metal?
Rossco
Moderator Gold
Moderator Gold
Post by Rossco »
There are plenty of filled blocks being used for road cars and in ambient temps well above what we get in the UK. It's cetainly not uncommon in the 455 fraternity.
It may as is being said be marginal in a GT40 but with a good oil cooler I'd still give it a go.
JP.
Post by JP. »
Just sell that GT40 to me :wink:
I am happy with a RV8 in it.
In real, I am in for a GT40 for a reasonable price. Must be pre '87 registration.
Without registration or post '87 I am not interrested as its pain in the as and wallet to get that registrated in Holland.
No problem with a project, but don't want to invent the wheel again.
If you know one please contact me.
'73 Ford F250, 6.7ltr V8
Building a GT40 mk2
Not actually sure what the makeup of the fill is...but it is often refereed to as concrete lol
So it sounds like it would be fairly permanent.
Lots of 2-pack resins are susceptible to weakening with heat, but it will probably take enough to cook the block and anneal it, so it looks like it's a sharpened screwdriver and a half-brick to chip it out.... :lol: :twisted:
SimpleSimon
Post by SimpleSimon »
unstable load wrote:Lots of 2-pack resins are susceptible to weakening with heat, but it will probably take enough to cook the block and anneal it, so it looks like it's a sharpened screwdriver and a half-brick to chip it out.... :lol: :twisted:
So thats a NO then? :lol:
