My matching numbers, factory built 'ride' is a 1984 Freight Rover Sherpa V8. If I could work out how to post pictures on this site then I would surely include one at this point. Basically, if you imagine a Rover V8 carb engine with a Freight Rover Sherpa wrapped around it then you will be in the right kind of place. It has a factory LSD rear axle as well, with drum brakes...'cos nobody needs to slow down in a hurry, do they? It left the factory in Birmingham with non-ventilated front discs and no anti-roll bars or power steering either. Driving it is challenging but rewarding.
I've spent the last year overhauling it, buying New Old Stock and generally fettling it. Luckily, previous owners have clearly spent much time and money on preserving it so the job has been straightforward. If working on a 1984 Sherpa can be described as straightforward...
Anyway, best wishes to all.
