I have fitted a 3.9 V8 EFI from a discovery 1 to my defender, with an auto box. The engine had 70k miles when I installed it, had been sat for the best part of 5 years. An oil and filter change (20W50) and the engine ran really smooth, couple of lifters were a little noisy but not worrying. Now have covered a couple thousand miles , and last weekend travelled to Anglesey. By the time I had arrived, a small misfire had developed, not very noticeable, more noticeable at low revs. After the weekends competition, driving home, the misfire had turned into 2 cylinders, and engine is now down on power. Got it out today and its running very rough, permanent misfire, not intermitent. I have swapped all the plugs, leads, dizzy cap, and coil (these were all new when i swapped the engine) which made no difference. I am assuming that the camshaft has finally worn past its usefulness?
If so, is there anything I should do to help the oil feed to the camshaft before installing a new camshaft? I have average oil pressure (around 20-35psi when driving) , would it be worth renewing the oil pump gears at the same time?
FYI, I did a compression test 2 weeks ago, and got 160psi +/- 10psi on each cylinder.
