I’ve got a rover v8 3.9Liter. which was an early upgrade from 3.5 with 93.5mm bore.
Some time ago I discovered that the engine was losing water.
I also saw that some white fumes were coming out of the crack case.
After removing the heads I could see some head gaskets in very bad condition.
Corroded around all the water passages.
Nr7 cylinder was steamed a little.
On the other bank the gasket short cut all 4 cylinders..
All liners are on deck level, so no liners are under the deck.
So quite convinced having found the problem, I reconditioned the heads flatten them, crack checked etc….
So after refitting the engine is running perfect, very balanced no temperature variations…
No vapor out of exhaust.
BUT still some white fumes, vapor to be precise, is still coming out of the crack case when hot.
Questions:
-I did not drive the car yet, so perhaps it is still condensation of water that was in the crackcase? Could it take a while when all water is out of the oil? I’ve got 15liter oil….
-If not, could it be that the lines are loose and leaking only on the bottom side, and not on top?
-Is there another way how water can come into the crack? Through the front cover channels?
Thanks......
