4.6 with sd1 front cover
ewokracing
Have thought about it, but it's the other things like a computer, fuel pumps, etc etc.unstable load wrote:Why not do the whole engine, including the Efi? That way, you have the coil packs and ECU etc, meaning you have some wiring ( OK, a lot of wiring) changes to make, but you will end up with a very nice set-up.
There is a thread about your question, either here or on the Rover Forum, and, there are a few that have done the Efi engine transplant, too.
At the moment I have access to a dead 4.6 with a slipped liner, plus I also have an offenhauser 4bbl manifold and a few carter carbs that may fit.
If I go EFI, I'm also not covered by insurance and I'd have to get it engineered which is not cheap.
Dave: planning to go Jag rear end with outboard jag brakes.
1976 Rover p6b.
current: stock with K&N filters
future: some sort of thundering V8 with a supra box.
ewokracing
nah! It's been done by a few p6b guys and to be honest, the rear end of a p6 is so typical of British engineering. Over engineered where it doesn't need it, critically under-engineered where it needed strength.
The input shaft into the diff is barely thicker than my finger. wtf!
I'll more than likely be using a p6b front cover... I'll make a thread once the engine build kicks off. Ideally I'd like roller rockers and matching lifters etc. Can't see it happening though...
1976 Rover p6b.
