4.6 with sd1 front cover
Lads,
Can anybody who has carried out the sd1 front cover on a 4.6 give me some advice. I am after a fast road cam nothing stupid and without having to pocket the pistons and change valve springs any suggestions? Did you get your cam machined to accept the cam retaining plate? I intend to use the sd1 sump and pick up pipe any problems there I know the block has the old position for the sd1 pick up but does the crank clear the sump. The crank pulley needs a spacer who is best to get this from. Any suggestions and tips greatly appreciated Cheers.
If you are using a distributor, you don't need the cam retaining plate.
I got my spacer from RPi.
I might even still have it - I can have a look over the weekend.
But any machine shop or bloke with a lathe can make you one. They're pretty straightforward.
Many thanks for the replies, I suppose the cam without the retaining plate will just resort back to sd1 where any thrusting hits the button on the sd1 cover.I just wondered if it was a modification carried out to prevent wear.Any one used a Kent h218 cam from Rimmer brothers I am after a straight swap cam for the minute. Chris did you have to modify your sump in any way. Cheers.
Cam plate
If any one else has a cam plate available for sale give us a pm, I don't use one on my front cover but will be changing to the crank oil pump front cover so will be looking for a cam plate..
Bish
Bish
Current project
1972 mgb v8 4.6 roadster
I run a 4.6 with and SD1 front cover. I do run a retainer plate, I don't like the idea of just using the thrust created by the dizzy to control the end float of the cam. I also run a vernier timing gear setup, this did cause some clearance issues between the retainer plate bolts and the cam gear, I resolved this by thining down the retainer plate bolt heads.
- SimpleSimon
- Knows His Stuff
I think thats why TVR left them off on the later blocks(int serp and full serp)sidecar wrote:I run a 4.6 with and SD1 front cover. I do run a retainer plate, I don't like the idea of just using the thrust created by the dizzy to control the end float of the cam. I also run a vernier timing gear setup, this did cause some clearance issues between the retainer plate bolts and the cam gear, I resolved this by thining down the retainer plate bolt heads.
- russell_ram
- Getting There
ewokracing
Q: want to build a 4.6 to put in a p6b, so obviously I need an SD1-ish front cover as well so that I can run a distributor.
Is there a good source where I can read up on what bits I need? ie retaining plates etc, what's all that about?
1976 Rover p6b.
current: stock with K&N filters
future: some sort of thundering V8 with a supra box.
Why not do the whole engine, including the Efi? That way, you have the coil packs and ECU etc, meaning you have some wiring ( OK, a lot of wiring) changes to make, but you will end up with a very nice set-up.
There is a thread about your question, either here or on the Rover Forum, and, there are a few that have done the Efi engine transplant, too.
