New striker plates
New check straps
Glass should be going in tomorrow
Dont think the top bolts would need sealer ? or do they go into the actual oil casing ?
Using a Jag diff as it's tough and has a proper LSD - the 6 degree beam gives lots more grip, which in turn puts more load on the diff and the Cossie one is not too strongunstable load wrote:That welding is almost too pretty to stick away under the car......
You mention making a billet cover.. what are the brackets/tabs welded to the present cover going to be for?
