The gap will be so small that it will make no difference to the running of the engine. I have used open spacers before now that have been 10mm thick and you can only just tell that the throttle response is not quite as good at around 1200 RPM.chris-stockton wrote:yeah, ive got two of em, just wasnt sure if it was necessary to get gaskets that seal up that centre section
