TRS TA Performance Cylinder heads
I had a low end shunt on mine which we could not cure
Dale at Bailey sorted mine out and it drove like a dream after that
I worked on many troubles that look crazy and there seems no remedy.Coops wrote:I had a low end shunt on mine which we could not cure
With no doubt it takes time for fully understanding the complex data
you get from a MS log.
But with no doubt these log informations contain much more data, especially
what makes the MegaSquirt react as it does. So with these informations and
good skill the results must be better than only watching dyno and AFR.
So its very pleasant to fiddle out a nasty problem by yourself and gives
some nice progress in knowledge. It only needs time and patience (and MS).
Andreas
Andreas
- SimpleSimon
- Knows His Stuff
Low end shunting can often be masked by dialing out ign advance and richening thing up a little on the RV8 running a plenum, when off cam mine only behaves at around 12.5 AFR below 2200rpm so have set the WB closed loop target values at that which works quite nicely, open loop was not an option for me in this zone because when temp conditions changed so did the AFR and hence the lurching I really am on that ragged edge of driveable and bloody horrible and the richer mixture is the only thing that keeps things in check, idle no issues I run that open loop at around 13.5/14 all self inflicted of course I am running a mech 238 cam
it does behave better than I expected and is surprisingly punchy midrange but revs likes a mad thing
Yes, Alpha-n is a pain and should only be used when cam does not
allow speed density.
Around idle the mapping can be made quite fine and fiddeling with
the y-axis is worth to spend a day on it.
I was very astonished that with speed density under full load
some pulsations at some revs spoiled the fuelling.
Seems that MS sees significant manifold pressure and leans mixture.
I had to swap to blended Alpha-n/SpeedDensity because I could not
get rid of that problem.
..... all a good job for the Megalog Viewer.
Andreas
Andreas
- SimpleSimon
- Knows His Stuff
I run speed density as I know the benefits and glad my new motor spec just about props this up because my vac signal at low speed is piss poor but I am glad I stuck with itDaveEFI wrote:I'd guess a lot of these problems are due to using Alpha-N rather than Fuel Density?
A long shot I know.
Has anyone using the TA/TRS heads have a template for cutting the valley gasket please before I bugger up my new gasket trying to work it out.
That would be great if you could please mate,
mine came direct from TA,
no gasket listed have to cut your own,
so going to use either a tin one or a composite one cut to suit,
how thick is the ally out of interest??
Thanks Mark
PM sent Mark,
thank you for your help
