Which manifold have i got???
I'm getting ready to sort out getting a ported inlet manifold and ported trumpet base with bigger trumpets,
BUT unsure which one I have now (been a while), I think its a 3.9 inlet, reason why I ask as all my pipe work has been made to suit this manifold outlets etc,
the number on the inlet is ERC9119 done a quick search and saying early hotwire p38 96>
I'm sure its a 3.9 inlet we used.
mmmm I'm lost then mate,
as never had one of them lol,
just did another search and it came back as 3.9 on another site, totally confused now lol,
cheers mate must get together for a cuppa
It could be the number on the casting applies to different versions, depending on how it is machined afterwards.
I think the early hotwire has the 'platform' the flapper EAV sits on, but the fixing holes not there. Later manifolds have the heater outlet there, so I'd guess a different casting number. Think I've got most here - so will take a look later.
The thread size for the CTS also changed along the line. As did the holes for the injectors.
Think with trumpet base, the main difference is the various outlets for vacuum to the servo and so on.
Hi Eliot,
they are its just the water outlets are different, and all my hoses are in silicone and been made to suit the outlets on the 9119 manifold, I'm still certain its a 3.9 base
Andrew sounds good, I'm just off to see if the second manifold I have stashed away is also a 9119 if so I may send that one away for porting then I know it will be ok with my hoses
Will also place a wanted ad as you never know whats out there for sale now days
nope other manifold is an old flapper one,
- SimpleSimon
- Knows His Stuff
