I began the tear down of my Pelican Blue B5 by 14:00 hrs.
As I suspected, the exhaust bolts in the centre section (the sleeves that join the catalysts to the mid mufflers) were too rusty to play nice. 15 years of use, and possibly 15 winters had taken its toll on the exhaust, from the front flexi pipes to the rear muffler. Although not holed, the whole assembly was in pretty bad shape.
As I am not running this exhaust with the V8, I simply undid the retainers, then ran a cutting disc through the damn thing. I was in a bit of a rush, as the engine was due to be picked up today, so I pulled the motor solo. I was later called by the buyer to ask if it was okay to pick the engine up next week. I agreed, after all, it's been paid for.
The 01A is all unbolted, propshaft has been removed, driveshafts disconnected, but left in situ. I just need to unbolt the clutch master cylinder, I won't be using it though, as I prefer to fit the aluminium version, which I have. The plastic ones have a habit of exploding under extreme pressure and load.
Pictures!
