Chysler 440 (7.2L) EFI conversion (Jensen Interceptor)
Why would you use copper leads with EDIS?
Like pretty well all ignition systems, it is designed for resistive leads - and in the case of EDIS, resistive plugs too. I'd read this before I even installed it.
Triumph-V8
Post by Triumph-V8 »
I had them at hand and gave them a try :-)
Andreas
Triumph-V8 wrote:I had them at hand and gave them a try :-)
Ah. Guess we've all done that. :D
But the EDIS HT connectors are made for 8mm leads - can you get copper ones in that?
Cobratone
Is a Spanner
Post by Cobratone »
DaveEFI wrote:Are you actually going COP or just one coil per plug? I'd be interested in the former, as it would be the neatest looking solution.
Not COP Dave but CNP (coil near plug) using Chevy LS3 coils like this
They normally fit four per side onto the rocker covers with a short lead to the plug, I'll be siting mine towards the back of the engine away from everything.
I've just twigged your name Phil - you have been knocking around in the megasquirt world for years! Possibly as far back as the yahoo group days!
Triumph-V8
DaveEFI wrote: But the EDIS HT connectors are made for 8mm leads - can you get copper ones in that?
Was no problem, I had little adaptors at hand to clamp
at the lead and push into the coil pack.
As I have the MSD6AL in use and it works perfect my
attempts towards the EDIS are only half way.
I had the MS1 in use, boosted it with the EDIS for triggering
and later kept the older board when swapping to MS2 daughter board.
So there was all the equipment already fitted in the engine
compartment to quickly try that out. But I stayed with the MSD....
Andreas
I've not tried MSD, but would say EDIS has been fit and forget here. Unlike the old Lucas ignition system or the Mallory Unilite which replaced it - both gave problems regularly.
minorv8
Post by minorv8 »
I have used MSD6AL in several cars and they have worked flawlessly. I also thought the same about Mallory Unilite, over 10 years of perfect operation until two dead Unilite modules this summer. No clear reason why, absolutely substandard help from supplier´s tech forum.
Anyway, this is my reason for going over to programmable ignition.
sidecar
Post by sidecar »
I also use an MSD unit (6530), I think that its a great bit of kit. I run with a locked out dizzy, the timing curve is programed into the unit via a laptop. I did not think that many other people on this forum were using the programable version of the MSD6AL system. :shock:
minorv8
Post by minorv8 »
Mine is the earlier 6420 or something that requires a normal dizzy. A programmable MSD would have been an option but I have had the Haltech ECU for years waiting to be fitted.
My Unilite burnt out the rotor arm and cap. Coil was the standard Bosch and standard Bosch plug leads. Was using the ballast resistor too. Never did know why.
EDIS probably isn't the best solution for a highly tuned engine, but mine is a standard Vitesse unit apart from Stage1 heads and MegaSquirt. And for that it was very cost effective, as the total cost using second hand EDIS ECU and coils was about £200.
SimpleSimon
Post by SimpleSimon »
DaveEFI wrote:My Unilite burnt out the rotor arm and cap. Coil was the standard Bosch and standard Bosch plug leads. Was using the ballast resistor too. Never did know why.
EDIS8 is a fine ign system so long as you bare in mind its hard coded to rev limit at around 6200/6400 RPM 8-) I have tested 3 modules and it varies slightly
Triumph-V8
Interesting, never heard of that!
Andreas
SimpleSimon
Triumph-V8 wrote:Interesting, never heard of that!
Others have noted it too :D http://www.msextra.com/forums/viewtopic ... 34&t=48433 it makes sense if you think about it the donar vehicles were hardly rev monsters 8) for most users I will stand by it being a robust ign solution :wink:
