Windage tray in a 4.6 - crank clearance?
ratwing
Post by ratwing »
I was amazed to find that my 4.6 block not only has bolt holes in the right place for the windage tray from my old engine (from a 1972 p6b) but the threads are tapped the same too :shock:
I'm not sure yet if there will be enough clearance for the crank, if not is there any reason why I can't use spacers between the block and tray instead of bending it down along the middle?
Just wondering if vibration might eventually fracture the tray if it isn't held against the block along the full length each side?
Re: Windage tray in a 4.6 - crank clearance?
ratwing wrote:I was amazed to find that my 4.6 block not only has bolt holes in the right place for the windage tray from my old engine (from a 1972 p6b) but the threads are tapped the same too :shock:
Apparently, all versions of the blocks are drilled and tapped the same.
spacers will work. just make sure you use lots of thread lock.
best regards
RoverP6B
Post by RoverP6B »
unstable load wrote,...
The 4.0 and 4.6 litre tempest engines were drilled and tapped for the windage tray, but the later Thor engines were not, although the casting was the same.
Ron.
4.6 Rover 3500 P6B
I have the windage tray on my 4.6 and no clearance issues at all with the crank and rods
ratwing
Post by ratwing »
Yes, having now trial fitted it I was suprised there was loads of room which was nice.
If I'm lucky the sump might fit without the aid of a hammer too.
If using sd1 sump you will need to do a little fetling with a hammer where the front journals of the crank are, i thought there was clearance until we started the engine lol
