coil pack v8
berty
coil pack v8
Post by berty »
iam interested to know if there any body who make a kit to convert chevy 350 sbc v8 to run coil pack ,using the LS series coils or similar any information will be great thanks
Spongo
Post by Spongo »
take a look at https://www.eficonnection.com/eficonnec ... fault.aspx they do a few options I believe
Range Rover 630R or otherwise known as the Money Pit
MS2 with switch MAPS for LPG
Techedge Wideband Sensor
MSD do controllers to drive LS coils, you would need to sort out a trigger.
best regards
berty
Post by berty »
Spongo wrote:take a look at https://www.eficonnection.com/eficonnec ... fault.aspx they do a few options I believe
thanks for this link ,
Cobratone
Is a Spanner
Post by Cobratone »
I would imagine that an EDIS8 module would fire the LS coils as wasted spark but you'd obviously need a controller for that plus a crank trigger. If you wanted to run one spark per cylinder set-up then you'd need a dedicated controller plus crank AND cam trigger. I'm in the process of ditching my edis and coilpacks to fit LS coils.
Anyone have a source of LS coils at a good price?
