Stupidly did not check the connections from the oil pump remote take off and connected them the wrong way round.
Obviously with a one valve in the filter oil was not flowing correctly around the engine but was giving me good pressure at the gauge (which made think all was OK).
Having discovered my error and swapped the pipes over, my engine (3.5 s) sounds much better now the lifters are pumped up. I've drained the oil and changed the filter - and strained the oil to check for debris, with little sign of metal particles in either.
The car is not on the road yet so has has only been driven in & out of the garage etc.
Am I likely to have done much damage?
