However, the different fuel rail fouls the flapper CTS plug. Might be possible to plug it in then fit the fuel rail, but not ideal.
Looking at pics of the later hotwire, the CTS is moved to where the thermotime switch is on the EFI - only a couple of inches or so - and the old CTS position left undrilled.
On my car, I'm not using the cold start injector, so the thermotime switch was removed and blanked off with a screwed in plug.
Sadly, the two threads are different.
A measurement of the threads using callipers into the manifold shows the thermotime one to be 12.4mm (guess at 14 x1.5mm?) while the CTS one measures 10.4mm (could be 3/8" NPT thread?)
What I don't have is a hotwire CTS to see if it fits the thermotime thread.
Be nice to have the same Junior Timer connector - as I've almost finished the new loom.
