Mix and match two gearboxes
aspira
Post by aspira »
Guys,
I have two gearboxes; a very solid 52A - out of a LandRover and a very tired G19A with a very wobbly driveshaft.
The box will end up in my MGB V8 conversion so I can't just use the 52A because the ratio's won't be any good and I don't want to stick the knackered but ideal 19A in for obvious reasons.
Can I take components out of the 52A and refurbish the G19A or is it better just to find a new half decent box to start off with, sell the 52A and scrap the G19A?
Any help much appreciated
1978 MGB Roadster
Converting to V8
Spongo
Post by Spongo »
Much better to get the box you need reconditioned properly, trying to mix and match bits from multiple boxes nearly always ens up with a very noisy and unreliable unit.
Range Rover 630R or otherwise known as the Money Pit
MS2 with switch MAPS for LPG
Techedge Wideband Sensor
+1 to that.
Had a P6 3500S bought with a so called re-con box which was noisy.
On stripping it nothing appeared worn.
Ended up replacing all the wearing internals with new genuine parts.
That worked. But cost.
