Ldv V8 clutch help please
Looking for advice please ..
i have a really bad left knee and looks like an op is due ...
Firstly i have looked at the elctronic clutch option and its far too much money for me ..
I would like to convert to autobox ...i have a good lt77 in there if anyone wants to swap
Or a way of making the clutch a lot lighter or making some sort of hand cluch ...
Possibly a motorcycle clutch master cylinder attached to the gear stick ??
any ideas and advice please ... [/code]
Like this
http://www.s-v-c.co.uk/product/lockheed ... ype-servo/
Damn they have gone up in price, 10 years back £65
A good few years ago a friend had a modified motorcycle clutch leaver on the gear stick with a remote servo in the line after loosing his left foot. It worked after quite a bit of fiddling. As is motorcycle master cylinders do not push enough fluid to operate a car clutch so need fitting with a bigger piston and a longer stroke, they then give nothing like enough effort without the servo. A servo on a foot operated clutch can be a bit wooden and lack feel making the hand clutch option better for doing smooth get away.
best regards
best regards
Have a look at this link:http://www.classiccult.com/blog/saxomat.html
Volkswagen had "automatic" Beetles in 60s. The clutch was operated via vacuum clock plus lots of small gadgets. Basically the clutch worked when the driver moved the gearlever. Aging boxes turned into gear grinders ...
Several UK makers offered an auto clutch some time earlier. BMC and Hillman, for example. Think it was made by Smiths. The BMC manual for my MG Magnette ZA covered it. I've never actually seen one, though.minorv8 wrote:Have a look at this link:http://www.classiccult.com/blog/saxomat.html
How about something like a bike brake lever and cable that pulls down on the clutch pedal
It leaves everything usable for any other driver and by mounting the lever on the gearstick would be a neat project
Ian im not too worried about other drivers as its only me insured in the van )
Im not sure wether with a bike clutch lever that i would get the range of movement required ..
The current master cylinder i have has 1 3/4 inches of travel ..
so i was thinking of making a lever with a greater throw ?
