Question, because my mate has no clue and I'm an electronic idiot too:
he has a electronic Autometer speedo connected to the Rover SD1 auto box. The needle swings from left to right and it seems that something is not working right. Is there a need for a special adapter etc.
The SD1 speedo sensor is active - it contains electronics, rather than just being a simple generator. Maybe a type of hall effect. One side is connected to +12v - the other to the speedo. So may need the correct load (to ground) to work properly.
Pitschi wrote:We have 2 cables from the gear box. One we connected to the speedo, one to ground. The cable from the speedo to +12V.
So have you connected the signal wire to 12v also.? The speedo unit has it's own 12v supply terminal.
I think you should try a 12v supply to the sender as per normal sdi wiring ( usually a white wire) and the other sender wire to the speedo signal terminal.
stevieturbo wrote:Most 2 wire sensors will generate their own voltage.
Sometimes the device this is connected to will be polarity sensitive, sometimes not.
Generally 3 wire are hall effect and require a voltage supply. ie 5-12v ground and a signal wire.
really you need to know what the speedo wants to see then you can set about achieving it
I have the wiring diagram for the SD1 and that shows a 12v feed to the sender. Maybe the body of the sender is the third wire, ie earth.
Regards Denis
As far as I know the SD1 sensor has electronics inside it - ie transistors etc that require a power supply. I'd guess this is to generate a near constant level square wave pulse - a simple alternator would produce a sine wave of varying voltage which would be more difficult to detect.
It's of a sealed construction, so difficult to get inside it to be sure.
I have an electric Autometer speedo together with LT77 box. I used a broken LT 77 sender and made an adapter to physically connect it to a Autometer sender. AFAIK all Autometer electric speedos have the same internals so any instruction will be OK.
I did the conversion over 10 years ago and had to really think back how it was done. I machined a new speedo housing/bearing ( http://www.rimmerbros.co.uk/Item--i-22G1486U ) with a threaded boss for the Autometer sender. My box was a mechanical speedo version so I used a sppedo drive pinion from that box.
I think I have a scrap sender for SD1 box somewhere. I have to check if I can find it and see how that can be modified.
