I'm toying with the idea of getting one to drop into my SD1, been looking around at the Jaguar and Lexus V8's, but the Audi seems to offer more on paper, but not a common conversion I believe?
That's kinda my thinking, I have a Megasquirt kit going onto the existing RV8 I have, so presumably that should be capable of running the Audi lump and most other modern powerplants?kiwicar wrote:Hi
I think they are a typical modern multicam engine, make excellent power, go on for about 400k miles if you change the cam chain and tensioner every 100k very clean efficient on emisions so give good fuel economy and run the throttle and gearbox off the engine ECU so are a total and expensive pig to get to run properly in anything but the original chassis.
best of luck
I reckon the O1E 'box would drop straight in, but getting the driveshafts anywhere near the wheels and keep the V8 within the engine bay, just wouldn't happen. If I was to go 4wd (which I've done some research into, one of the many ideas I've explored on the P6), it would be a system similar to the old Sierra 4x4, transfer box behind the gearbox and a driveshaft to a differential beside the sump, with driveshafts attached to each front wheel. Sounds easy!unstable load wrote:sowen, you know you want to, so why not find a Quattro and stick that in the SD, just for giggles. Having seen your work on the P6's and the SD you are more than capable, IMO.......
The later Lexus V8s had 300bhp. They're not 'nortoriusly expensive' to fit manual conversions to, there is a place in the UK that do kits for BMW boxes for a grand, plus clutch and gearbox you're looking at about £1500. The kit I have is a custom adapter for the auto bellhousing to R154, it's just a plate. I do have a rather expensive hydraulic clutch though.sowen wrote:Yes I was following that one, nice install but the time/expense to get a 230 or 260bhp engine which is notoriously expensive to fit a manual 'box to was what prompted me to start looking around and thinking about other alternative modern powerplants which with a little ingenuity and basic fabrication could be adapted to fit? The Audi 4.2 in standard form comes from 300bhp, and some of the other late 90's OHC V8's of about 4ltr capacity also push out similar numbers higher than the Lexus lump. So far the Audi 4.2 looks to be a really good all-rounder, except the price of donor cars is still high compared to the others.
Sometimes it just isn't about the cost, but the fulfilment from actually building something unique that works
