Andrew!v8250 wrote:Hi Perry, I don't know the true flow rate of the core, the input/output hose connection diameters are the same. When looking for radiators the majority of suppliers simply offer same size/design as a std radiator which, as you quite rightly say, only really gives gains due to weight. The reason why I opted for the Mulfab unit was the sensible increase in size, both core and top & bottom headers [take a close look at the pic' above], this should provide good volume/cooling capacity. The radiator fits under a std bonnet and does not protrude too low below the chassis rails :. no risk of damage. Re' core material, like for like core thermal txfr is circa' 60% better with a copper core assuming they're the same core format. The Mulfab unit uses a danish manufacturer core [can't remember the name right now...], they're very well proven with good fin-to-tube contact area. Many MG V8 racers with high o/p John Eales engines use the Mulfab unit so my choice for this unit with the little 4.0 TVR engine will be fine. Not sure what else to say except I think the radiator is the best available for design/size/efficiency to cost.mgbv8 wrote:V8250 ! Do you have any idea of the flow capacity of the ally rad you are thinking of using? I've been toying with the idea of converting my MGB rad to an ally one. But they seem to look the same size. The copper cores and fins of a stock rad will conduct heat away much better than aluminium core tubes and fins. So if the rads are similar in design the stock radiator should be better than the ally one shouldnt it? Although the ally rad will be a lot lighter than a brass and copper rad I think ! As a conductor of heat, copper is about 60% more efficient than ally from memory? Perry
Also, I have noted your good advice re' engine stabilizer bar and it makes some sense to install a secondary bar lower down to counteract driver side engine lift. From your experience, what's the engine vibration transfer levels like when a second bar is installed?
Rgds,
Andrew
The extra steady bar will not give you any noticeable vibration tranfer noise or feel if the engine is still on rubber mounts. If JE is happy with these rads for his circuit engines I'll be happy to use one
Pel
