top hat liners
- Seight-V8
- Knows His Stuff
top hat liners
hello all,
can anyone recommend v8 developments for doing top hat liners for the rover v8, been looking around and prices vary a lot.....
Just want someone to do a good job.
Looks like i'll be doing this over the winter months, so want to make a few decisions now.
cheers
scot
cheers
scot
I use Knight Engine Services for my top hat jobs.
Do you actually have a slipped liner/cracked block? I would only do this work if the engine needs it or your engine is already in pieces and you have a grand burning a hole in your pocket!
What really helps the non-top hat 4.6 engine is running is quote cool and rich when it is under load, by rich I just mean not as lean as Rover ran them, you can run them as lean as you can get away with when under cruise conditions.
- Seight-V8
- Knows His Stuff
No im not really sure yet, but I been having problems for a while....
Loss of coolant
liquid leaking from outer edge of head/block.....looks & feels like coolant/oil
problems maintaining lambda readings
Not stripped the engine yet, as i will do this over winter, but that's the only way im going to know.
Compression test of the engine is 215psi +/-5% on all cylinders, so head gasket is fine.
what else can this be.....
taken a photo of the leak, its mainly coming from the middle cylinders....on both banks....but looking underneath is leaking all along the edge of the block between the heads, and making a mess underneath the engine.
http://i875.photobucket.com/albums/ab31 ... C_0253.jpg
Scott
Loss of coolant
Scott
Does all sound a bit odd!
It would be worth making up some plates that you can bolt over the coolant holes in the block, you can seal them with silly bodge sealant, you can fit a car tyre valve to one of them then slowly presurise the block. The pressure should maintain and a bit of soapy water sprayed around the top of the block will indicate whether you have an issue......Why didn't I just say to a pressure test!
- Seight-V8
- Knows His Stuff
yes....been looking at a pressure test, i'll know more when i strip it down.
i know my block is from 1997, and has the numbers 3.0 wrote in the centre of the valley of the block, could this be the dimension of the thickness of the water jacket for my block?
This should mean i have the better block at 3mm, and not the thinnest at 2.2mm....which is why i never thought it would be a problem when i built the engine 4 years ago.....
cheers
scott
cheers
scott
Yep the 3.0 will be the block thickness, there was also a colour code system, red being the best blocks. Hopefully it will onlt be a minor issue when you strip the engine. I guess the piston crowns will also help you determine whether the is an issue. (steam cleaned)Seight-V8 wrote:yes....been looking at a pressure test, i'll know more when i strip it down.
cheers
scott
- Seight-V8
- Knows His Stuff
they did my tophat liners 4yrs ago and recommend them also
