I am sure someone here on the forum can help with this, I must have something wrong as the engine is overheating pretty quickly and water doesn't seem to be circulating around the whole system.
The car is fitted with a header tank as high as I can possibly get it in the bay, where I know other guys have them installed in these cars. The inlet manifold is an Edelbrock Performer.
On the diagram above (borrowed from another thread!) I have the following connections:
- C to H (with a small take off pipe from the top hose running up to point A on the header tank as on the drawing and I have no point B as it is a header tank with a single connection and 15psi cap)
- I have no point I as on the drawing as my rad has no cap, it is an original MGB radiator mounted 90 degrees from normal orientation.
- Dto E
- F to bottom side of my heater matrix via a copper pipe.
- The pipe from the top of my heater matrix comes out and down to the connection not shown on the drawing on the back of the inlet manifold, this is where my heater control valve is fitted. There is a bleed valve fitted in this pipe also.
- G to L
There is no stat installed inside the housing at the moment, so this is one thing out of the equation.
I hope this makes some kind of sense, if there is anything else you need to know, or isn't clear please let me know and I will do my best to clear it up.
Below are a couple of links to pictures showing the water pump housing, where you can also just see the top hose, and the second picture shows the connections to the heater matrix and rear of the inlet manifold.
https://drive.google.com/file/d/0B-2QaJ ... sp=sharing
Many thanks in advance for any help that can be offered.
Lenny
