Rover V8 heater connections
Might be handy for someone although be quick.I just ordered some for this(40mm by the way):
http://www.autosiliconehoses.com/
Are doing free postage until the end of the month.If you put ASHHOSE in at the discount voucher stage theres an extra 15% discount!
Ran the engine today for the first time in months.Heater works great(albeit turning the heat off didnt really seem to do much unless I wasnt giving it long enough).I fit a temp controlled unit to the rad fan as PO just relied on an on and off switch,it switches in and out ok although I arent sure what sort of temp I should set it to switch in at?I have a laser type temp reader.Just got to check coolant level in the morning and top up.Let it tick over for half an hour and it ran fine.Because I wanted to use the original Wolseley dash gauges I had to cobble an old Austin 1300 temp gauge innards with the Wolseley white face.It reads fine albeit reading backwards(I have to transpose the C & H letters)but sits towards the H end.I wonder if I maybe need a different sender or a resistor in the circuit.
http://i1374.photobucket.com/albums/ag4 ... da964a.jpg
