Fuel Pumps :(
Fuel Pumps :(
Looks like the fuel pump I replaced back in 2012 has started complaining,
it rattles and buzzes very loudly now once the fuel temp gets a bit warm,
the pump is a bosch 044,
replace with the same? or try a different make??
single or twin pumps?
Replace with the same
But NEVER NEVER NEVER let it run dry.
Even make sure it is preprimed with fuel (blow or suck it through the pump) before turning it on
And if you have ever opened one up to have a look inside you would understand why.
Always install with an over sized supply with nothing i the line, as close to the tank as possible and as low as possible to get as much tank head as you can get. If that pump has to draw fuel (suck) then it will die very quickly. Should have 15mm feed to it if possible.
Noise when fuel warm could be cavitation - a pumps worst enemy
Ian Anderson wrote:Replace with the same
4.5L V8 Ginetta G27
Re: Fuel Pumps :(
Are you actually experiencing a fuel supply problem ?Coops wrote:Looks like the fuel pump I replaced back in 2012 has started complaining,
They can get noisy, doesnt always affect performance. And at only 2 years use, they should not be failing.
What is the supply from tank to pump like ( pipe sizes, lengths etc ) ? and is it same sound with a full tank of cool fresh fuel ?
Pipe size is about 15mm min I'd size from tank may even be bigger.
Never use to be noise on a full tank cold but it's started being noisy when first used now too gets louder longer you use the car. Sat in a traffic jam Sunday on way back from the track was unbearable the noise pitch keeps changing too
Have read on another forum one guy has to change his every year
If he's changing pumps that often, he's either mental or his supply is very bad.
I've been using the same pumps for 7 years or so now. I've driven for as much as 4-5 hours non stop, been stuck in hot traffic etc. Yes at times they can get noisy, but they always still work.
Just been told to check my ROV on the tank as these have failed on capris causing problems and upsetting the pump
Anything that can interupt or restrict the fuel flow to the pump is bad.Coops wrote:Just been told to check my ROV on the tank as these have failed on capris causing problems and upsetting the pump
And yes that would include a non-vented tank
same valve used in capri tanks as mopar, dodge and Jeep
new one ordered and will be here the weekend
Sealed cap on mine mate.
Don't know if it's blocked but to get the valve out have to drop the tank anyway so if it's not blocked I have a spare
- SimpleSimon
- Knows His Stuff
Is your cat and tank ex Efi or ex carb?
If carb it would not have a built in sump.
With new engine in and driving it with new tyres etc you could be managing to uncover the tank outlet on cornering ( having fun at roundabouts)?
But you may be running the pump dry for a tiny period without even realising.
Belt and braces fit a low pressure pum to swirl pot and run your Bosch pump from that
