BLOS LPG CARB (variable venturi mixer errr gas S.U. carb!
bclancy
Post by bclancy »
Hi Guys
Thought I'd post a few pics of my newest toy :D Has anyone seen or used one of these? In theory it looks a pretty good upgrade from the usual gas ring mixer! The guy selling em states almost no reduction in airflow compared to the normal mixer
bobtail84
Post by bobtail84 »
ooOOoo that looks nice. What sort of dollar did that cost? and have you got any more info on it please..
jeff
Range Rover 3.9 with MegaSquirt and EDIS
www.essex-ms.co.uk
bclancy
Post by bclancy »
Hi bobtail
Cost £110 on flea-bay, I will look for a link for you! :D
It will be a while before I get a chance to test it, but it looks the nads! Its basically an S.U. for gas, you can fit it as aplain mixer, BUT you can also just plum it from the vapouriser and forget all the e.c.u's and soleniods and just set the mixture/idle as per petrol carb!! :shock:
And like an S.U. you can also change needles (well make the slot larger in the pipe where the gas is from) and alter the fueling at diffrent opening points too! I really think this is worth some BIG H.P. gains on sihgle point lpg :D 8) !! They also state a ROCK SOLID idle too
bclancy
Post by bclancy »
Teesdale_landrover
Post by Teesdale_landrover »
that looks a great idea,
do forktrucks use something similar?
V8 Classic rangey builder, tdi destroyer
bclancy
Post by bclancy »
no idea as for forklifts, but its a nice quality item and a stonkingly good idea........ but the proof of the pudding!
Well, will find out in the near-ish future! and then I will post the results
Teesdale_landrover
so its like a carb but without the throttle mechanism
does it go before a throttle body
bclancy
Post by bclancy »
you got it, just place it infront of the T/B and the engine vacuum lifts the plastic piston/slide (like an S.U. / stromberg) progresively and opens up the tube (think s.u. needle). It has an adjustment for idle / idle mixture and main jet (from what I can tell) and you can also open the slot in the same way you would thin an S.U. needle
All in all, the theory sounds spot on :D
hope that helps
Brian
bclancy
Post by bclancy »
IF it works well and as I will have a 'spare' 3.9 soon, I'm even contemplating a siamesed twin T/B with two of these as a little project, maybe a twin turbo on gas using a 'suck through' setup......Hmmmm, probably a pipe dream, but an LPG twin turbo would be intresting! :twisted:
Teesdale_landrover
but how does it fuel at idle against a close butterfly, maybe it goes after the tb?
or the butterfly needs a bypass?
bclancy
Post by bclancy »
the butterfly CANT be closed or how would the engine idle on a normal mixer? and the BLOS has an adj screw that lifts the slide to get the required mixture/idle speed
Teesdale_landrover
would it work through the idle control circuit on a injection vehicle though?
to be honest i dont know, but im pretty sure the mixer systems i have seen, the tb is closed at idle
bclancy
Post by bclancy »
well, as far as I can tell it must be open a very small amount on mine as it couldnt idle when on gas otherwise. There is just no other route for the gas/air mix to enter the manifold as my mixer is before the T/B and all are as far as I know? (apart from inj setups and thats totally diffrent!)
Anyway, wont know for sure until its fitted and setup and that is going to be a few weeks maybe a month or two yet :roll: so we will have to see! :D
Looks OK
Does it ahve any hot water jacket?
If not how will it stop freezing up as the LPG vapourises?
IAn
bclancy
Post by bclancy »
Hi Ian
There is no water jacket, but then there is nothing on a normal mixer ring either! I have read some very positive reports on other forums (4x4) and they all sing its praises. One chap went on the rollers before and after fitting and was getting 97% of the power he was getting on petrol!! :shock: :twisted:
But as I said before, the proof of the pudding is in the eating! lol
Regards
Brian
Return to “LPG Section”
