Switching back from gas to petrol
oilyfingers
- Helpful or Confused
I,m not sure what system i have fitted (it was already installed), but when i switch to gas from petrol there is sometimes a small increase in rpm which settles quickly, but when i switch back to petrol it cuts out. I dont have this on the road yet so all this is at tickover. Any ideas?
oilyfingers
- Rossco
- Moderator Gold
EFi suffers from other related issues.
If you dont have injector emulators then the ECU will have gone into default mode and will lean the mixture right out. Also if the fuel pump has been cut (which it should be) the again that and the lean issue can make the engine die at idle.
As Chris says try giving it some revs and then switching over.
oilyfingers
