The actual hose stubs are fairly big, but the hole the water passes through when it leaves the impeller is pretty small, maybe 5/8".Ralphh85 wrote:cheers for the help!
maybe i wont worry so much then, also will wait till i get a pump before i make any decisions.
do you know the ID or OD of the pump inlet/outlets?
Ralph
You should invest in the electronic controller as well, to make it all work more efficiently. I planned to, just never got round to it.
