Rover V8 Help for a newbie
Lord Steve
Post by Lord Steve »
Good morning all
I've acquired a 3.9 Rover V8 as a re-build project having sucessfully rebuilt a couple of Pintos in the past.
Having stripped the top end off I am frustrated by the lack of co-operation from the crankshaft pulley bolt. Soaking in WD40 hasn't had any effect and I wondered if anyone has any suggestions....
Steve
softdash3.9
Post by softdash3.9 »
Use either
a) windy gun, my prefered method
b) or large breaker bar use a block of wood inside the crankcase to stop the crank turning, you may need a hand to restrain the block assembly
Std rh thread so anticlockwise, it will be tight!! 24mm socket iirc
Regards
Royston
i use a windy gun too
I have a 12 volt (runs off car battery) impact driver bought from Maplin ages ago which moves such things with easy - without having to lock the crank. It delivers lots of torque for a split second. There are similar ones on Ebay.
However, with the sump off, jam a length of wood between crank and block and use a breaker bar.
Lord Steve
Thanks folks - that's the excuse I needed to buy an impact wrench!!
roofman
Post by roofman »
yea these bolts need "shocking" off for instant results...impact gun all day :)
91 classic vouge...2" lift...31-12.50/15 muds and running a 3.5
I've got a long bit of angle iron drilled to allow it to be bolted to the rear of the crank. Then a 3/4 drive socket set with a long bar, and they soon come out.
I've also seen the flywheel wedged with a 1" piece of angle wedged between the ring gear and the block.
shaunod
Post by shaunod »
If the flywheel is still attached use an alan key through the bell housing bolt hole opposite the starter, lock it into the ring gear .. I use this method on just about every one I do and it has always worked for me.
If some nice fella has put half a gallon of loctite on the bolt thread .. you may need a little heat on the head of the bolt .. now you have an excuse to buy a gas axe!
Post by ian.stewart »
if all else is un available a pair of mole grips attached to the ring gear will stop the engine rotating
