Bosch 044 Fuel Pump, Check valve or not
Posted: Mon Dec 26, 2011 8:54 pm
by leylandracer
Should i be using a check valve on a Bosch 044 Fuel Pump? Ime just on with putting the upgraded pump on, The old (Standard) Sytec pump didnt have one fitted, Ime using a 8mm barb fitting, Just a bit puzled
Thanks, Steve
Posted: Mon Dec 26, 2011 10:10 pm
by Eliot
I dont use one, mainly because my pump didn't come with one originally.
Just means your rail dosn't remain pressurised when off.
Posted: Mon Dec 26, 2011 10:57 pm
There is absolutely no need for a check valve.
Posted: Tue Dec 27, 2011 1:00 am
by leylandracer
Thanks...
Posted: Tue Dec 27, 2011 10:56 am
by Coops
i was not running one, but now i am
only difference i have found hot starting is a lot easier now.
Posted: Tue Dec 27, 2011 11:12 am
Coops the PIKEY wrote:i was not running one, but now i am
Yes - there's a factory fit hot start mod on my SD1. Basically, above a certain radiator temperature, it shuts off a valve fitted to the fuel rail return, and bypasses the inline resistor. So the pump runs up to maximum pressure, while cranking.
Posted: Tue Dec 27, 2011 5:31 pm
by SimpleSimon
Thats an added bonus then, said valve was essential on the old Bosch K/KE Jetronic systems to stop fuel percolation
a left over device I feel from that system.
