I've got a pretty much standard 3.5 apart from a unknown upgraded cam, edelbrock 4-barrel set up, a Mallory duel points dizzy and a RPi LPG system with RPi AMP.
I've got this little lump in my Ex Ambulance LDV Convoy.
Over the last couple of weeks I noticed the occasional miss and within a couple of seconds back to normal.
Two days ago I started her up and she was missing badly, I thought it was the plugs in need of a change and the damp weather as it had been a year since my last change and I had bought them 4 months ago but not fitted them. Changed them on the road side but no change, still missing badly. limped home about 3miles away, very poor power. The following day I changed the coil for a spare one I had, and put a new condensor on and checked the points gap. no change!
Today I put a new set of cheapy HT leads on to eliminate a faulty lead (I have Magncore leads at present, 2yrs old) but nothing. did a compression test (All plugs out pedal to the metal and cranked over 3 compressions with the gas and petrol off) on all 8, ranging between 150 and 160 psi.
Checked the servo hose and capped it to eliminate servo leak, nothing! still missing badly!
Any ideas?
