I just managed to break what I think is probably a crankshaft position senor. Had a look on internet and can't seem to find a reference to it.
Its off an '84 TVR 350i.
The sensor is one lead (of three) out of a plug. Guess I have to buy sensor, plug etc.
Any ideas what its called, where I can get one from?
Thanks,
BBT.
Crankshaft position sensor ?
Bobbybedtime
Bobbybedtime
Bobbybedtime
Re: Crankshaft position sensor ?
No CPS on the flapper EFI - the ignition is all done by the dizzy. What that is a diagnostic device for checking ignition timing, but I've never known anyone use it. Just as easy to use a timing light. So unless you're keen on the engine looking original, just remove it and throw it away - it has no function as regards the running of the engine.Bobbybedtime wrote:Hi,
Thanks,
BBT.
Bobbybedtime
