Oil pump housing in timing cover
Posted: Sat Apr 07, 2007 9:08 pm
by Coops
my oil pump housing in the front timing cover is scored on the side walls, can i gently wet and dry this back to make it a bit smoother? or will it cock up my oil pressure????
im going to order some new gears, as these are scored also (4yrs old now)
Posted: Sat Apr 07, 2007 9:13 pm
by katanaman
you would do more harm than good M8 polishing the scores out.
Posted: Sat Apr 07, 2007 9:19 pm
by Coops
cheers mate,
just replace the scored gears then
Posted: Sat Apr 07, 2007 9:23 pm
by katanaman
yes M8 the scores on the side wont damage the new gears as they don't actually tough. The really bad news is when the top or bottom is badly scored. Just a thought but the new pump gasket isn't too thick is it?
Posted: Sat Apr 07, 2007 9:25 pm
by dnb
Could you not go for an intermediate serpentine setup? A whole new cover with crank driven oil pump isn't terribly expensive.
Of course the cost of all the other bits soon mounts up...
Posted: Sat Apr 07, 2007 9:27 pm
by ppyvabw
Mine had high sharp spots on the walls as if it had something nasty through it chewing it up. I gently sanded those off, but didn't polish the scoring out.
by Coops
katanaman wrote:yes M8 the scores on the side wont damage the new gears as they don't actually tough. The really bad news is when the top or bottom is badly scored. Just a thought but the new pump gasket isn't too thick is it?
never thought about that mate, it does seem thicker than im use to,
its pink one side black the other, i use to have a pale grey gasket,
Posted: Sat Apr 07, 2007 9:30 pm
by katanaman
yes its always pale grey I have used and their very thin.
Posted: Sat Apr 07, 2007 9:36 pm
by Coops
i recon this is my problem, the gasket is thicker than a piece of A4 paper
Posted: Sat Apr 07, 2007 9:41 pm
by landybob_v8
if the oil pump face is too scored too spray glue a 400 grit wet and dry down to a block of wood and rub it up and down
but you probably knew that anyway lol
Posted: Sat Apr 07, 2007 9:47 pm
by Coops
yeah done that befoe mate, may get that again just to remive a few of the marks from the pump face,
its the gasket thing thats got me thinking now.
Posted: Sat Apr 07, 2007 11:49 pm
by ihatesissycars
I've first hand experiance of this. The first time i rebuilt a v8 and put in my capri i had very low oil pressure, enough to make me really worry (despite the warnings that they have uber low pressure at hot idle) so i rebuilt the pump with new gears and a remote filter (that came with a new and improved base) but when i put the new base on i noticed the gasket that came with it was silly thin compared with the one i originally used and once it was running again with the new base and gasket the oil pressure was decently high but the only big difference between the two was the gasket.
Ever since i've not used a gasket and only used liquid stuff. In doing this i've never had and pump gear to pump base interface problems and superb oil pressure.
Posted: Sun Apr 08, 2007 12:17 am
by Coops
what liquid stuff is that gav?
as im thinking my pump gasket is too thick.
its thin but not wafer thin like im use to.
Posted: Sun Apr 08, 2007 7:21 am
by ihatesissycars
Just a liquid gasket cleverly and carefully applied. My pump gears still clear the base when using this however a friends pump gears locked up when we did the same to his. . . . .
The thin gasket i had and used that time though i got from Paul at v8 tuner, it came with the mocal remote filter and base i used so it could well have come from mocal with it rather than paul adding it into the kit.
