Smallblock Ford into '93 range rover
Hello everyone,
Just joined up and was wondering if anyone has done such a conversion?
I want to use an EFI 351w and adapt it to the ZFHP22.
I've done much searching and can't seem to find any such adaptor/bellhousing.
Cheers!
Cheers!
I can't see it being that tricky, but you might want to consider a ford 302/gearbox combination that already exists and conver the tail cone/ output shaft arrangment to fit the RR transfer box (like Elliot has done with his SBC into his Dackar http://www.mez.co.uk/gearboxfaq.html just think you may find it cheeper and simpler.
Thanks Lads,
I could use an AODE/4R70W and adapt to the BW transfer(or use another Ford/BW transfer) but I was trying to keep the ZF in place. I'm led to believe the ZF can be built rather tough?
Overfinch certainly did a SBC but used a T400.
Here in Australia they use the ZFHP26 6spd auto behind our modular 5.4's in the Falcon but of course this is very different trans with its ECU built into the valve body ie; not condusive to swapping into another vehicle because it requires torque data from the PCM.
Pete.
Pete.
