main cap bolt size.1989 3.9
Posted: Sun Feb 25, 2007 9:08 am
by nickm
Could anyone tell me what size and what thread type the main bearing cap bolts are?I have a slightly damaged thread in the block and would like to run a tap down it.Thanks Nick
Re: main cap bolt size.1989 3.9
Posted: Sun Feb 25, 2007 9:51 am
by adamnreeves
I do not know Nick but if I am not certain I usually turn the bolt 2-3 turns through the die I think is right to check the size.
nickm wrote:Could anyone tell me what size and what thread type the main bearing cap bolts are?I have a slightly damaged thread in the block and would like to run a tap down it.Thanks Nick
by Rossco
9/16" UNC comes to mind but I'd have to check when I'm in the workshop later
Posted: Sun Feb 25, 2007 10:42 am
by jrv8
They are 1/2" UNC
Jim
Posted: Sun Feb 25, 2007 10:47 am
by Rossco
Oh well I was only a 16th out
Posted: Sun Feb 25, 2007 10:51 am
by nickm
Thanks very much for that.By the way does anyone have a P6 or early RR alternator bracket as I need one to get the engine to fit in my Westfield.Thanks Nick
Posted: Sun Feb 25, 2007 10:59 am
by Rossco
Is that the alloy one that's kind of triangular?
Posted: Sun Feb 25, 2007 1:43 pm
by adamnreeves
Nick,
I am building an SEiGHT. Have you looked at the westfield alternator bracketry.
nickm wrote:Thanks very much for that.By the way does anyone have a P6 or early RR alternator bracket as I need one to get the engine to fit in my Westfield.Thanks Nick
Posted: Sun Feb 25, 2007 9:19 pm
by nickm
No.Does westfield supply the bracket?[my engine is an early 3.9].Cheers Nick.
Posted: Sun Feb 25, 2007 10:37 pm
by adamnreeves
I think the 3.9 runs the interim cover? If so then yes.
nickm wrote:No.Does westfield supply the bracket?[my engine is an early 3.9].Cheers Nick.
Posted: Sun Feb 25, 2007 10:50 pm
by katanaman
adamnreeves wrote:I think the 3.9 runs the interim cover? If so then yes.
Very very few 3.9 engines ran the interim cover.
P6 alternator bracket isn't going to work for it either unless you extend it or fit an SD1 front cover and P6 pump.
Posted: Mon Feb 26, 2007 7:43 am
by nickm
I am fitting the SD1 cover and P6 water pump.
