Lexus 1UZFE into P5B rover
redsunbeam
Post by redsunbeam »
My aim is to put the engine and gearbox out of a lexus ls400 into a 1968 rover p5b. I'll only have a week to strip the lexus of everything i need to get it in and running. Has anyone got any experience with these engines with regard to whats needed to get it to run.??
Rover P5B
Post by ian.stewart »
kevcon
Post by kevcon »
Hi redunbeam
took me a bit to find it again, but think i have come up trumps for you. On the LRO one guy has put a lexus block into a range rover classic. take a look i think it will help a lot.
kev
www.lro.com/forum/viewtopic.php?t=36556
I'd imagine wiring would be the hardest bit if retaining the original ecu etc
kevcon
Post by kevcon »
apparently the engine loom and ecu just unplug and are quite straight forward. its the clutch and fly wheel that are the problem.
follow link above most is explained.
redsunbeam
Thanks Kev, planning on using the lexus gearbox aswell so should be relatively easy :? :?
Rover P5B
plastic orange
Post by plastic orange »
Post up pics of progress. I bought an LS400 mk 4 recently and have been most impressed with the engine so far. Make sure you do the cam belt and ancilleries when the engine is out (if it is needed).
Pete
Image Image
redsunbeam
Have bought the engine, Its a lexus 4ltr v8 complete with gearbox,
and its going in this,
Rover P5B
Lewis
Post by Lewis »
Best of luck! Should be a great conversion, just hope it fits OK - a very wide engine at the best of times! :)
Make a brilliant car at the end of it though, look forward to seeing the end result! :D
topcatcustom
Post by topcatcustom »
I'm a bit lost- the engine doesn't seem to have "Rover", "Ford", "Chevy" or "Mopar" stamped on it??? :? :lol:
TC
topcatproduction wrote:I'm a bit lost- the engine doesn't seem to have "Rover", "Ford", "Chevy" or "Mopar" stamped on it??? :? :lol:
:lol: But it does have V8 FOUR CAM 32 on it, though.
redsunbeam,
Is that an auto box?
Definitely keep us updated with pics!
ChrisJC wrote:Definitely keep us updated with pics!
YES PLEASE, I am probably going to do the same with my P6 so any gen you pick up will be most welcome.
redsunbeam
Spent the last week or so identifying the wires i need in the new loom, with that done its time to get the engine out, and see how big a job its going to be,
Old rover v8 and new 1UZFE together. At this point the new engine looked HUGE.
Next step is to throw it in the hole,
Am going to have to convert the steering to rack and pinion as the steering box was in the way, and the sub frame will need massaging to give a bit of clearance, but on the whole not too big a job.
Rover P5B
minor8pot
Post by minor8pot »
if you need to have the sump at the rear for subframe clearance,you can use the sump of the soarer as its all at the rear,where the ls400 is mid or front mounted...a guy i know also does the wiring on these engine swaps he charges 250.00 plus petrol to come to you...good luck...
