3.5 v8 lucas 35 de8 wiring plz help
rousecapri
Post by rousecapri »
have a 3.5 v8 with 390 holley fitted
running points dizzy at min
i have the lucas 35 dizzy with the small flat electric box that goes with it,what i would like to know is how to wire it up please. :)
The box will be a ballast resistor.
Do some searching on this forum, as the same question has been answered a few times before.
Pocket rocket
Post by Pocket rocket »
Re: 3.5 v8 lucas 35 de8 wiring plz help
Post by CastleMGBV8 »
rousecapri wrote:have a 3.5 v8 with 390 holley fitted
Do you mean the little black box that is mounted on the body of the dizzy in which case it's the amp and the dizzy will be a 35DLM8 which requires a Lucas DLB198 coil or equivalent.
If it is the amp your describing does it have 2 or 3 terminals? Nomally, from memory only two connections are required from the coil + and - but will have to check which way round thwey go as a long time sice I wired mine up.
rousecapri
dizzy
its the early type i have with the silly ballast resistor
have junked the resistor and wired the dizzy with 12v and removed the ballast resistor from the capri.I had a 12v coil kicking about wired this in and she started first time,sounded much better than when running the old points dizzy
thanks for all your help :D
