hello all,
So attached to the fuel rail on my 4.6 gems engine, is a strange valve item.
The incoming fuel goes through this item then in to the fuel rail.
It has no connectors just a round dome, with pierburg 95T342 and 7.2180.12 on it.
Anyone know what this item does, and do i need it?
So aint got any pictures, and no results from google or LR parts.
scott
unidentified item
- Seight-V8
- Seight-V8
- Seight-V8
It will be a simple diaphram accumulator to maintain a constant fuel pressure in the fuel line from fuel pump pulses or more likely from the the injectors firing on the fuel rail.
I dont know how the fuel system works on your car but when an injector fires it could - if the fuel rail volume is not very great and there is a long distance from the pump to the rail - lower the pressure in the rail so that next injector would fire without full line pressure. The accumulator has a spring loaded diagram that provides that volume and maintains that constant pressure.
That my thinking from my hydraulics theory
Andrew
Andrew
4.5L V8 Ginetta G27
- Seight-V8
there's no sign of it on the 4.6 parts diagram, and very little on google about it.
but according to pierburg should be fitted to the 3.9 & 4.6 engines.
Going to re-fit it to my fuel rail, even though i am just finishing of the change to the VEMS efi.
So must have a useful purpose.
Found alot of info on RX8 engines that have them fitted.
scott
scott
