serpentine oil pressure relief valve help
I'm rebuilding my serpentine timing cover. Got to the point to re-install the oil pressure relief valve and realised I'd forgotten the order it came appart in... :oops:
Looked through my 4.6 overhall manual, got to the oil pump relief valve remove/ re-fit part BUT I also have a small metal tube with shamfered ends which looks to fit inside the piston with holes (see pic below). I can't see what this tube would do and if fitted like I mentioned above it just slides through to contact the edge of the serp pump! can't be right can it??
An help much appriciated.
This is the order in which I reassembled my front cover parts:
No idea what the little tube is for though.
Excellent, cheers chris.
Makes more sense now.
I guess it must be a stop. Curious as to why it isnt' in the manual though???
Chris, did you have any trouble re-fitting the relief valve plug and o-ring?
I tried fitting it last night with new o-ring and lots of oil but couldn't push it in enough to get the cir-clip in?? The relief valve plugs fit fine without the o-ring.
The old o-rings do look very flat! not very "O" like.
The new o-rings do seam rather stiff, maybe they've been on the shelf a while? they're supposed to be new!!
Maybe I need some more wheatabix :lol:
Firstly, I did have a problem sourcing o-rings as the Land Rover parts catalogue doesn't give a part no., yet the manual says to change them!
So I went to an o-ring specialist and got them matched up.
But, to answer the question!, I didn't have any real trouble getting them in. I did lubricate it well, and had to tap them in, but they did go in OK.
Thanks Chris,
Think i'll get new o-rings and then use a little more persuasion :wink:
