Single plane manifolds
Posted: Sat Sep 12, 2009 6:13 am
Does anyone know where to get single plane manifold nowadays ?
Welcome to the well-known V8 Owners Forum, no matter what you drive if its V8 Powered you'll be made very welcome.
https://www.v8forum.co.uk/forum/
If they did it would look exactly the same as the above picture! I got mine from Wildcat, it's a Harcourt inlet with wildcat stamped on it. The other option is to wait around for a huffaker to turn up on ebay however many of them have been over ported and/or drilled for nitrous nozzles. A post by Gregg55 on here a while back included data that shows the harcourt inlet to be superior anyway.crayefish wrote:If only they made a Victor Jr. manifold for the Rover......
From what I remember, Vicotr Jrs are much taller.... they are at the extreme end of the single planes....HairbearTE wrote:If they did it would look exactly the same as the above picture! I got mine from Wildcat, it's a Harcourt inlet with wildcat stamped on it. The other option is to wait around for a huffaker to turn up on ebay however many of them have been over ported and/or drilled for nitrous nozzles. A post by Gregg55 on here a while back included data that shows the harcourt inlet to be superior anyway.crayefish wrote:If only they made a Victor Jr. manifold for the Rover......
The size of the runners in the eddy 180 are suited to the standard ports in the RV8 heads, If your heads have bigger ports then the manifold will need to be port-matched.minorv8 wrote:I have currently the Performer manifold but I am slightly sceptical whether it has enough flow capacity past 5500 rpm. Edelbrock designed it for 3,5 litre engine with idle to 5500 range. I am running a 4,6 litre engine and shift at 6300 rpm at 1/4 mile. The peak hp at rollers is at 5600 rpm.
Now that I have the Merlins fitted the issue is more than interesting...
Do they make the Performer RPM for the Rover? That would shift up the power band of the manifold by about 1000. It seems to be a very popular manifold for the sbc. Also the airgap ones too as they run a bit cooler.minorv8 wrote:I have currently the Performer manifold but I am slightly sceptical whether it has enough flow capacity past 5500 rpm. Edelbrock designed it for 3,5 litre engine with idle to 5500 range. I am running a 4,6 litre engine and shift at 6300 rpm at 1/4 mile. The peak hp at rollers is at 5600 rpm.
The ports and valves were bigger, the manifold was port matched. I have run with 1" spacer.The size of the runners in the eddy 180 are suited to the standard ports in the RV8 heads, If your heads have bigger ports then the manifold will need to be port-matched.
If your old heads had the standard size valves in them then your 4.6 was never going to be able to rev very high!
